I was just wondering how other people drive touchdowns from RCP's for Camera Racks on an ultrix?
In the past I have used the Joystick in on Evertz router panels but the ultrix panels don't seem to have this?
Thanks,
Kai
Hi Kai,
If you are referring to triggering a crosspoint when pushing on a joystick it is possible to do this with Ultrix and an Ultritouch by adding in a GPI device into your solution.
The NK IPS https://www.rossvideo.com/routing-systems/nk-ips-network-bridge/ along with the NK GPI https://www.rossvideo.com/routing-systems/nk-gpi-general-purpose-interface/ can be configured to provide a crosspoint change upon GPI activation.
Once you have these devices you can program the NK-GPI to trigger a specific set of crosspoints on an ultrix based on which GPI is triggered. The Joystick would also have a GPI connection that would allow you to toggle between two GPI states (on and off)
Hope this helps.
62 Auriga DriveNepean, OntarioCanada, K2E 7W6
Phone+1 613 228-0688Emailcommunity@rossvideo.com
LoginJoinHelp/FAQEventsrossvideo.com
Terms and ConditionsPrivacy PolicyDMCA Policy
