Connectivity
  • 1.  Ultriscape load multiviewer layout from tallyman
    Posted 11-14-2020 20:36
    Is it a UDP-command(or other) where i can load a layout in the utriscape from tsl Tallyman? It would be awesome to be able to load the different layouts from tallyman.
  • 2.  RE: Ultriscape load multiviewer layout from tallyman
    Posted 11-14-2020 21:44
    All of your layouts will appear as potential source objects when you select Refresh I/O
    In your Ultrix source table, create a source with the layout name placed onto the cell of Video level 1. Do this for as many layout as you need.
    You will also need to create a destination with your head output as the physical port in your destination table.
    Add the new sources an destinations to a test control panel. Then route source "layout" to destination "Head"
    The same Crosspoint can be used at the TLS system with the GVG native router protocol.
    #Ultrix
