Connectivity
  • 1.  VNC for Ultritouch
    Posted 12-21-2020 09:57
    Is it possible to setup VNC server on the Ultritouch?
    If I don't have an ULTRITOUCH-RTR License, can I load Ultrix panels? Or can I only run custom panels ?
    dargs
  • 2.  RE: VNC for Ultritouch
    Posted 12-21-2020 15:27
    Hello, thanks for your question.
    The ultritouch no longer requires the rtr license. If you get in touch with technical support https://support.rossvideo.com/hc/en-us we will get your system upgraded. Once upgraded you can create custom panels and use the standard ultrix templates.
    Unfortunately VNC is not available with the ultritouch however I have added this feature as an enhancement request with the product manager.
    #Ultrix
