Connectivity
  • 1.  Setting FS or Gearbox externally?
    Posted 11-25-2020 12:52
    We're using Cerebrum to control the routing in our Ultrix. We have Framestore and Ultrispeed liscenses active and I was wondering if it's possible to set a FS (enable/disable) for a source externally. Same for gearboxing; is it possible to control the enable/disable function through Cerebrum (via scripting).
    We'd like to avoid that people without the knowledge to go into Dashboard, have to login and switch stuff on and off, since one mistake can throw the entire configuration off... We want to make it as fool proof as possible ;-) (If such a thing exists)
    Kind regards,
    Arne
  • 2.  RE: Setting FS or Gearbox externally?
    Posted 12-02-2020 19:18
    Thanks for your question.
    Unfortunately these parameters are not exposed via third party protocol sand are only available via dashboard OGP.
    #Ultrix
  • 3.  RE: Setting FS or Gearbox externally?
    Posted 12-03-2020 08:38
    Hi, thank you for the reply.
    Arne
    #Ultrix
