Connectivity
  • 1.  Ultix sub nodes not showing up on tree view
    Posted 08-16-2021 11:02
    I went to a facility to update their router.  I dont know what they did but none of the sub nodes for config, destinations, sources etc appear on the tree view.  I tried reloading both Dashboard and updating router to most recent firmware but it still does not show.
    Any suggestions?
    Conrad Slater
    Slater Sound and Video Engineering
  • 2.  RE: Ultix sub nodes not showing up on tree view
    Posted 08-16-2021 11:24
    Hi Conrad,
    I would start with checking the "Remote controller" mode, which (unless you have a separate controller) should be un-checked. Please go to Ultrix-->System Status --> Database and be sure that "Remote Controller Mode" is not Checked.
    I hope that this would solve your problem. If not, you may share your screenshots and we will investigate further.
    Regards,
    Milos
    Milos Ciric
  • 3.  RE: Ultix sub nodes not showing up on tree view
    Posted 08-16-2021 15:49
    Hi Milos,
    Thanks for much for the tip!  Yes,  "Remote Controller" mode was checked.
    I was able to use Teamviewer to change that setting, reload the database I needed and after a reboot, the sub nodes are all back!
    Conrad Slater
