Hi David,
Your NK-NET needs to be online for you to see any of your NK devices. The RCP-ME shows up as it is ethernet connected, but the rest of the equipment is all T-BUS and needs to go through the NK-NET to be configured and controlled. Once you get the NK-NET online, the rest of the T-BUS devices, including the NK-GPI, should appear in your Dashboard tree.
Is this a new install? Was the NK-NET ever online? Have you changed the IP address at all? Are there other devices in the chain beside the NK-3G16 and NK-GPI?
You may want to contact support to start a ticket.
techsupport@rossvideo.com.
Hope this helps.
Joe Davenport
Solutions Architect
