Virtual Production Solutions
  • 1.  Lucid Studio & Voyager
    Posted 03-25-2022 07:33
    Hlw Expert how to  change Material in lucid studio :)
    Pradeep Dahal
  • 2.  RE: Lucid Studio & Voyager
    Posted 03-25-2022 13:02
    Hey Pradeep,
    If you look at the Router panel of Lucid Studio there is a Material button that allows to select any material from the Voyager project and add it to the Router source's.
    Once exposed there you just have to make sure the item on which you want to assign that material is exposed as a Target in the Router and just assign the material to it as you would do to assign an image on a virtual screen.
    Note that, by default, Lucid Studio Router will replace every material of that item (if it has more than one). To limit the action of the Router assignment to a specific material slot, that slot must be named with the prefix "TG_" in Voyager.
    Hope that will help.
    Regards,
     Vince.
    Vince Horlait
    Virtual Production Product Prime
    France
  • 3.  RE: Lucid Studio & Voyager
    Posted 03-27-2022 05:04
    thank you so much:)
    Pradeep Dahal
