Hi.
I´m working with a Xpression system that have a XP Designer and a XP Player working on separate machines. I´m using version 3.60 and trying to use the window capture material.
It works fine inside Designer, but when I want to call the take item that refers to that scene and material, I only have a black texture and a warning "No capture window has been selected (this is default behaviour for this shader)".
Is there any solution for this or Xpression Players can´t have window capture materials assigned?
Thanks,
Charles
