Hi Anthony,
In the keyframe editor, In the channels pane, CNTL Click all the attributes you want to move. Then in the graph draw a box around the keyframes (with your mouse) you want to move. Hold down SHIFT+CNTL. You should now be able to move all the keyframes left and right in time.
