  • 1.  Script Event, not member of a string?
    Posted 06-05-2013 18:22
    Attempting to run this script event:
    if Len(Text) > 0 then
    Text.visible = True
    else
    Text.visible = False
    end if
    But I can't compile because of a message telling me that " 'visible' is not a member of 'string' "
    Any suggestions?
  • 2.  RE: Script Event, not member of a string?
    Posted 06-05-2013 18:27
    Text is the value of your text object...
    Try self.visible = true/false
  • 3.  RE: Script Event, not member of a string?
    Posted 06-05-2013 18:31
    I added " self.visible = true/false " prior to "if Len(Text) > 0 then " but I am still receiving the same message
  • 4.  RE: Script Event, not member of a string?
    Posted 06-05-2013 18:36
    All your code has to be correct to be valid...
  • 5.  RE: Script Event, not member of a string?
    Posted 06-05-2013 18:43
    When I throw it all together, it looks like this:
    dim Text as xpTextObject
    Text.visible = True
    else
    end if
    text="@"+Text+" "
    Now the only message I am getting when trying to compile is from the 1st line - "Text is already declared as a parameter of this method"
  • 6.  RE: Script Event, not member of a string?
    Posted 06-05-2013 18:44
    Thank you for your help Vincent
  • 7.  RE: Script Event, not member of a string?
    Posted 06-05-2013 19:27
    I still cannot compile the script event, any other suggestions?
  • 8.  RE: Script Event, not member of a string?
    Posted 06-05-2013 19:45
    If Len(Text) > 0 then
    Self.visible=true
    Text = "@" & Text & " "
    Else
    Self.visible =false
    End if
  • 9.  RE: Script Event, not member of a string?
    Posted 06-06-2013 15:35
    Thank you Vincent, that worked. I appreciate it !!! :)
