  • 1.  Preview screen
    Posted 05-30-2014 21:14
    Hi All,
    Is there a setting to choose which frame on a scene the preview screen displays? Currently some of the scenes have longer animations and they do not show all the text boxes in the preview screen when I am trying to edit them.
  • 2.  RE: Preview screen
    Posted 05-30-2014 21:21
    Hi Don,
    Actually it's pretty easy. Under the "take item" tab you can give in the preview frame. You can do this in the sequencer for a single scene and in the editor for every instance of the scene.
    I hope this will help you.
    Kind regards
  • 3.  RE: Preview screen
    Posted 06-02-2014 20:05
    Worked! Thanks... cant believe I didnt see that
  • 4.  RE: Preview screen
    Posted 06-02-2014 21:23
    You can also right click on the top of the scene director timeline and choose "set preview frame at position marker" and you'll get a little P in the scene director to show you where the preview frame is set. When these scenes get added to the sequencer the preview frame in the sequencer will default to what was set from the editor.
  • 5.  RE: Preview screen
    Posted 06-03-2014 19:42
    good tip! thanks!
