  • 1.  Effects
    Posted 09-04-2012 21:25
    What is the Effects tab in the Object Inspector? How do I add effects and what are those effects? Thanks.
  • 2.  RE: Effects
    Posted 09-04-2012 22:20
    Hi Carlos,
    The effects tab is for adding the chroma keyer effect to objects. Currently the chroma keyer is the only effect that is added from this menu. Note that you need the chroma keyer license to use the chroma keyer option.
