  • 1.  FS ANIMATED BACKGROUND LOOP ISSUES
    Posted 08-14-2013 20:31
    Ok, I'm using version 5. I brought in a normal FS amination .mov file to use as my background. I added it to my scene and when I play it out it is choppy and studdering. When I play any of my lower third animations they play nice and smooth. When I ran a FS animation .mov background in version 4 the other day it played smooth. Anyone know why this is happening in version 5 and maybe how to fix or correct the issue?
    thank you
    Jen P.
  • 2.  RE: FS ANIMATED BACKGROUND LOOP ISSUES
    Posted 08-16-2013 14:17
    It isn't recommended to play MOV files directly from XPression. They should be converted to AVI's using the XPression video coder. Certain codec's of MOV's will play OK (such as MJPEG encoded MOV's) but most formats are not playable in real-time. Which codec is your MOV file encoded with? The open source tool MediaInfo (find it on google) is very good at giving you the details of your media file.
    Also, you need to keep an eye on the performance meter at the top of XPression. If you are trying to play too many HD video clips at one time the performance meter can get very high. When it is over 100% you will start to see stuttering. Its generally recommended to play no more than 2 fullscreen HD clips simultaneously. Some very old machines could only play 1 at a time.
