  • 1.  Script Editor Documentation?
    Posted 12-22-2011 01:27
    There is any place I can download one? Thanks.
  • 2.  RE: Script Editor Documentation?
    Posted 12-23-2011 09:56
    The document that can help you is the "XPressionSDK" help file in the help folder of Xpression...
  • 3.  RE: Script Editor Documentation?
    Posted 01-21-2012 09:01
    Who can send'me documentation for scripting? tnx
  • 4.  RE: Script Editor Documentation?
    Posted 01-22-2012 02:38
    Danila,
    Vincents post above yours points you to the XPressionSDK help file in the help folder of XPression. That should give you the documentation you are looking for.
  • 5.  RE: Script Editor Documentation?
    Posted 01-22-2012 08:18
    I understand, but i'm a user & i'm working in this program and do not have access to CD and that file does not exist in c. That file it's small and if you can do a good deed remain grateful.
  • 6.  RE: Script Editor Documentation?
    Posted 02-01-2012 16:29
    Im not sure about ALL Xpressions come with the SDK file. Xpression Designer does not have it. Im not sure about Prime. Studio does.
  • 7.  RE: Script Editor Documentation?
    Posted 02-01-2012 20:19
    correct Designer and Prime do not have the ability to support the API. However was not aware that the documentation was stripped as well. But yes you won't see it under those circumstances.
    The XPressionSDK.chm is only 848kb. It is very thorough information about the SDK and API. The size is more to do with it being compiled HTML an thus just text.
