  • 1.  Taking one scene off line from within another scene
    Posted 11-02-2016 04:44
    I have an animated scent that transitions on, plays a video of a player holding a sign, waits for operator input then transitions off. I need to have the transition trigger another scene which holds a text field to also transition off. Any suggestions?
  • 2.  RE: Taking one scene off line from within another scene
    Posted 11-02-2016 19:39
    Use a script event on the scene director. The script event would get the other scenes take item and tell it to go offline..
    Something like this in a scene director script:
    dim takeitem as xpBaseTakeItem
    engine.sequencer.GetTakeItemByID(1001, takeitem)
    takeitem.SetOffline
    This script is assuming 1001 is the take id of the item you want to take off. Instead of takeitem.SetOffline you could use TakeItem.Execute to resume a pause, or put the scene online.
  • 3.  RE: Taking one scene off line from within another scene
    Posted 11-16-2016 23:25
    Looks plain and simple. Thanks Brian.
  • 4.  RE: Taking one scene off line from within another scene
    Posted 11-17-2016 15:38
    Hey Malthepal, you could also use a scene trigger on the out of the player scene that triggers a scene director in that other scene. You should place an offline event on that scene director to make sure XPression clears the scene from air.
