  • 1.  Datalinq keys with Excel in XPression
    Posted 08-13-2015 19:44
    I have used datalinq with textfiles (.csv) for a roll group. I now have individual thirds in a manual group and am using excel. Before I used the column and %relid% to have the text change (see first image). Does this relid not work with excel datalinq's? Is there a better code to use? I'll have multiple thirds with sequential id's in the group (see second image).
  • 2.  RE: Datalinq keys with Excel in XPression
    Posted 08-13-2015 19:46
    %relid% will work with the ADODB datalinq which can be used to read from excel sheets.
    Watch the datalinq Part 1,2,3 videos here for details: http://xpression.rossvideo.com/videos/
  • 3.  RE: Datalinq keys with Excel in XPression
    Posted 08-17-2015 19:31
    @bford Everytime I use a macro with Excel datalinq it fails and brings back nothing. If I use a csv and text datalinq it works. I watched the video but %relid% fails with my excel datalinq.
  • 4.  RE: Datalinq keys with Excel in XPression
    Posted 08-17-2015 19:38
    Have you tried the ADODB datalinq like in the videos? I'm not sure if the Excel datalinq supports it.
  • 5.  RE: Datalinq keys with Excel in XPression
    Posted 08-17-2015 19:55
    ADODB works, so Excel datalinq doesn't support macros?
  • 6.  RE: Datalinq keys with Excel in XPression
    Posted 08-19-2015 21:14
    It doesn't support all of them.
    The ADODB connection is actually a much better way to connect to Excel files than the Excel connection. Anything the Datalinq Excel connection can do the ADODB connection can do better.
  • 7.  RE: Datalinq keys with Excel in XPression
    Posted 09-01-2020 15:18
    Is there any documentation on how to set up the adodb?  at the moment I'm using a rather larger excel sheet and converting it to a tab delimited text file.  We don't have excel on the computer housing the xpression so I was told the excel file won't work there.  but I have't had any luck initiating the adodb on that computer.
