  • 1.  Triggering Movements in Overdrive Rundown
    Posted 09-05-2012 19:00
    I have recently finished my training and starting loading in our new graphics package into Xpression, so we can premiere them together. I have set my supers to reveal on to the screen and with the event I have set on the Scene Director it is set to reverse direction and wipe off screen. (And when I test this through the sequencer it works) But when I load the graphic through my Active X plugin and try to run in through Rundown Control, I am able to have it wipe on the screen but it wont wipe off of the screen. Any thoughts on how to fix it? Are there any settings that may be off?
  • 2.  RE: Triggering Movements in Overdrive Rundown
    Posted 09-06-2012 14:30
    When you load through the active x plug in, and then run it from the interface, do you see the "paused" notification in the sequencer? Assuming you have a pause instead of simply running the scrollhead backwards.
  • 3.  RE: Triggering Movements in Overdrive Rundown
    Posted 09-11-2012 16:33
    Yes I do...I unfortunately don't have the ability to wipe it out when running it through Rundown Control. I can do all of the animations through my sequencer in Xpression, but when running it through Rundown Control, I can only show the first animation and it wont give me the ability to go through the other animations I have set up on Xpression.
