  • 1.  Missin text objects after a copy paste
    Posted 03-18-2015 19:34
    I created a graphic which has two groups each with two quad and two text objects. Since I'm lazy or efficient if you will, I just copy and pasted Group 1 to make Group 2. I animated Group 1 then animated Group 2, and when Group 2 animates on the two quads show up but the text objects are missing. But the fun part is when I view it with the animation controller not as a played back scene the text for Group 2 shows up fine. Had this happen in the past not sure what I did to fix it. Any ideas? Thanks,
    Mark
  • 2.  RE: Missin text objects after a copy paste
    Posted 03-18-2015 19:36
    Did you add the second text group/objects after you had already dragged it into the sequencer? If so, then the second text objects probably don't have any text set in them from the sequencer. If you re-drag it into the sequencer it should be ok? Or you can unpublish the text objects if you don't need/want to change their values from the sequencer side.
  • 3.  RE: Missin text objects after a copy paste
    Posted 03-18-2015 19:39
    Ha, thanks Brian simple solutions always seem to work the best and make me feel dumb. Worked like a charm after I re-dragged it over.
