  • 1.  Layout mode vs Sequence mode
    Posted 09-11-2013 22:09
    Question. Is it possible if you have dual monitors to have "layout" mode open on 1 monitor screen and "sequence" mode open simultaneously on the other monitor screen? Right now I have to click between layout mode and sequence mode or hit (f3)/(f4) to swap between the two.
    Jen
  • 2.  RE: Layout mode vs Sequence mode
    Posted 09-12-2013 02:15
    It's not possible. You can only be in one mode or the other at a time.
