  • 1.  Xpressions Video Coder - Convert 30fps to 60fps
    Posted 09-24-2015 18:08
    When converting 30fps files to 60fps, the video plays back 2x the speed and half the length. Is it possible to convert 30fps without changing the speed/length?
  • 2.  RE: Xpressions Video Coder - Convert 30fps to 60fps
    Posted 09-25-2015 14:33
    Not by using XPression. The original video file must be re-rendered at the correct frame rate from the program it was created in.
  • 3.  RE: Xpressions Video Coder - Convert 30fps to 60fps
    Posted 09-28-2015 13:54
    thanks
