I write automation format files that are used to generate and send commands from an external Linux database server to a MS/Windows based graphic software program. How are you writing the syntax string for the line break command?
I've always written: [% CRLF %] for the syntax creating a line break command. That doesn't mean you are writing the command string incorrectly. There may be other factors involved that could be influencing the way the logic editor interprets certain command strings.
