  • 1.  Visual Logic & Actions
    Posted 02-26-2016 08:36
    I'm attempting to set up a 4on4 dropdown for a scorebug. It's animated in such a way that it goes online (drop down), pause then goes offline (back up) in one scene director. We're trying to set it up so that when there are 2 penalties on the clock, one for each team, it will automatically go online and once there is 1 second left on the clock, play through the remainder of the scene director and go back up and offline. I have the clock parts set up using logic, however I can't get the action to trigger.
  • 2.  RE: Visual Logic & Actions
    Posted 02-26-2016 14:33
    Without seeing what you've done, it's hard to tell you why it's not working. Can you share the scene?
  • 3.  RE: Visual Logic & Actions
    Posted 02-26-2016 14:42
    Here is an example of VL that would start playing a scene director when a certain text object is equal to a certain value..
  • 4.  RE: Visual Logic & Actions
    Posted 02-28-2016 23:35
    Put your mouse cursor over the yellow dot on the "Penalty Clock" object and check the value it's spitting out.
  • 5.  RE: Visual Logic & Actions
    Posted 09-29-2016 22:55
    Brian, I've tried the above VL and it doesn't seem to be working. I've tried to get it to trigger the clock on when the Penalty Clock is at 2:00 but I'm not sure why it doesn't work.
