I have set up a series of widgets and drop downs that work in conjunction to set up a series of scenes. It's one scene that can be configured in many ways. For example, it takes team1 and team2 names and chooses a number of textures applied to a number of quads in the scene.
The question is, I have the sequencer open, and when I choose something from a text list widget, it gets applied to the team name in all of sequencer items using that team (that's correct), but on which event do I put my script so that I can be sure it's executed? Keep in mind, I know I can apply it to text changed on a text field, but I have six widgets. I want an update (the script executed) no matter which one I change.
Should it be a scene script event? If so, which one? If it gets taken directly (via Ross Talk, for example) it should work, but it should also work if I focus it so that I can see a preview.
Is there a description of what all the events are? Sorry - I'm a programmer, not a graphics operator, so it might be obvious to some, but I don't know what "OnOnline" is as opposed to "OnSceneOnline" or if "OnRender" is a superset of "OnPreviewRender".
So, just again, in a nutshell - I should be able to change something on any of a half dozen widgets, and when a scene that utilizes that widget is focused or taken, the script should run first so that it works both when taken or previewed (focused).
Should I apply the script multiple places? Like on every text object that can be changed by any widget?
