I would like to embed a script into a scene that will do the following:
Cue/Take the scene and the next scene in sequence simultaneously. These two scenes need to animate on in sync to FB1 and FB2. This happens on a regular basis in our sequence and very quickly. Selecting both scenes and then ./ works - but this is too cumbersome in this particular environment. Ideally, it would be a script embedded on the first scene.
I appreciate any thoughts/help from the scripting gurus.
Thank you!
