  • 1.  XPression - DataLinq Server Export Issues
    Posted 02-27-2015 15:31
    Hey all,
    We are seeing a rather persistent issue when exporting graphics as PNGs with scenes that are data keyed. We ran a DataLinq server on a CSV file and are exporting various scenes in sequence as PNGs. However, often when we export we are forced to re-export several times as the first handful of exports on the same scene are incorrect. Meaning, when we export, the scene has the wrong data, the data is jumbled and distorted by what appears to be interlacing, and sometimes that data is not grabbed.
    If someone would like more info I can certainly supply that. I was just wondering if anyone could shed a little bit of light on this.
  • 2.  RE: XPression - DataLinq Server Export Issues
    Posted 02-27-2015 15:40
    What version and build of XPression are you running?
    Are the scenes you are exporting from the Seuqnecer using Data Pages, Datalinq Keys or just straight Datalinq?
    When you do your export are you exporting the scenes individually or exporting them by right-clicking on the group and doing a batch export?
  • 3.  RE: XPression - DataLinq Server Export Issues
    Posted 02-27-2015 18:34
    I've encountered this problem too. Sometimes they export with the correct data, and sometimes not. I've ended up having to go back to Layout side, put the scene (so it displays the correct data) to air and can then export as a jpg from the main viewport...
