I have two clips (each with a 3-point loop in material) that I need to play back-to-back seamlessly on a cue. The trick is, once the first clip is into it's loop, I will need to cue the second clip so that the frame of the online loop is on matches the first frame of the incoming clip. A dissolve won't work in this situation as the movements in the clip are sharp. Is there a way to have the incoming clip wait for a certain frame of the online clip to be played before it cues, or even better, on a cue have the online clip jump to a specific frame in the loop and immediately play the next clip? I appreciate any assistance.
