  • 1.  Script based on containing text
    Posted 11-17-2014 18:24
    Hello there,
    I'm sure this answer is on the forums somewhere, but I haven't been able to find it.
    What is the script for checking to see if a text field contains a certain word? For example, I'm trying to add this script on the text object itself, on the "on set text" tab:
    if this text contains "xyz" then
    run this command
    else
    run a different command
    I appreciate the help, thanks!
  • 2.  RE: Script based on containing text
    Posted 11-17-2014 18:50
    Run in "OnSetText" for a text object.
    dim quad as xpBaseObject
    scene.getobjectbyname("Quad1", quad)
    if text.contains("Off") then
    quad.visible = false
    end if
  • 3.  RE: Script based on containing text
    Posted 11-18-2014 02:11
    Perfect, thanks!
