  • 1.  Layout and Sequence discrepancies
    Posted 07-10-2015 20:58
    Continuously having issues with discrepancies between my Layout of a graphic and the final Sequence that is used on air. In the Layout, the keyed animation plays perfectly. In the Sequence, it doesn't work at all. Why? The graphic shows up, but does not animate as I've keyed it. I've tried restarting the program. Any ideas to what's going on? By the way, this is ONLY for new graphics I've produced and not for existing graphics, which still seem to work fine.
    I'm under a lot of pressure here and am hoping for an easy fix for this.
  • 2.  RE: Layout and Sequence discrepancies
    Posted 07-10-2015 21:01
    Can you provide a copy of the project and tell us what version, build and edition you are using?
  • 3.  RE: Layout and Sequence discrepancies
    Posted 07-10-2015 21:07
    Sure, is there a way to isolate the individual scene I'm having issues with, or do I send the whole .xpf file (which is rather large, contains our entire news program's graphics)? Who do I send it to? Sorry for being so clueless.
  • 4.  RE: Layout and Sequence discrepancies
    Posted 07-10-2015 21:14
    Xpression Studio SCE v5.11 build 2550
  • 5.  RE: Layout and Sequence discrepancies
    Posted 07-13-2015 14:51
    You can upload it here:
    app.brickftp.com
    User: Xpression
    Password: rossvideo
    Folder: XPression Projects
    Make a new project (with the same frame rate and resolution). File > Import > From Project. Select the scene you want to import. Make sure the issue still occurs. File > Export
    If you need some more help feel free to ask
  • 6.  RE: Layout and Sequence discrepancies
    Posted 07-13-2015 20:53
    I attempted to upload multiple times by dragging the folder into the window. The files show progress bars uploading, but only a few files are showing up for me when I try to view them afterwards. Maybe, they're showing up on your side? The folder is titled ANN.
  • 7.  RE: Layout and Sequence discrepancies
    Posted 07-13-2015 21:22
    It's a write folder only (as it is public facing) so you won't be able to see the files after they upload :)
    I downloaded the project(s) you uploaded, but there is nothing in them. It doesn't look like you imported a scene from your project to your new one.
    Email me at gmillward@rossvideo,com
