Hi, I want to drive the string values of the tab numbers of a single text object, so I can make charts like this:
"profession: medic doctor nurse" , using just one text object (I'll drive the strings with an xml), this way I can optimize my scene by using few text objects, and also I can take advantage of the alignment and position property of the text tabs.
as a side note, is there a way to assign different fonts to the tabs?
