  • 1.  Auto Sort Election Results & Ideas/ Suggestions
    Posted 10-08-2015 22:11
    Hi everyone,
    Up here in Canada we are hold a federal election October 19. We plan to show results from our local 3 riding's. What is the best way for displaying election results in Xpression? Further to that if I just make text boxes how can I have the 6 candidates automatically sorted by total votes; as the night goes on all we have to do is enter vote numbers and xpression will sort and display candidates with most votes at the top and least votes at the bottom, is that even possible. Our station is a very small operation, we have a very basic version of Xpression v4.0 (no extras like MOS, datalinq etc...) we have upgrade support still, is this something that could be done with a newer version of Xpression?
    Any ideas or suggestions on what we could do differently would help. Unfortunately our company isn't wiling to put more money in so am having to make things work with the software that I have.
  • 2.  RE: Auto Sort Election Results & Ideas/ Suggestions
    Posted 10-13-2015 17:16
    What system is feeding you the election data?
  • 3.  RE: Auto Sort Election Results & Ideas/ Suggestions
    Posted 10-14-2015 21:10
    It will be through a national results website. We will have to manually enter the data.
  • 4.  RE: Auto Sort Election Results & Ideas/ Suggestions
    Posted 10-14-2015 22:04
    Here's is a script that should work. Unfortunately I don't have an example of it in a project. Let us know if that's enough to go from or if you need some help implementing it.
    dim names(14) as string ' holds names
    dim party(14) as string ' holds parties
    dim scores(14) as double ' holds scores
    dim scorestxt(14) as string ' holds scores as a string
    dim txtobj as xpTextObject
    dim highest as double ' highest score found in loop
    dim highestIdx as integer ' index of highest score
    dim i as integer
    dim j as integer
    ' Get the names and scores from the page and store into local variables
    for i = 1 to 11
    if self.GetObjectByName("Name " + CStr(i) , txtobj) then
    names(i) = txtobj.text
    end if
    if self.GetObjectByName("Party " + CStr(i) , txtobj) then
    party(i) = txtobj.text
    end if
    if self.GetObjectByName("score " + CStr(i) , txtobj) then
    scores(i) = CDbl(txtobj.text)
    scorestxt(i) = txtobj.text
    end if
    next
    ' Display in sorted order.. Loop over 6 text fields
    for j = 1 to 11
    highest = -1
    highestIdx = 0
    ' Scan for the highest score remaining to be shown
    for i = 1 to 11
    if scores(i) > highest then
    highest = scores(i)
    highestIdx = i
    end if
    next
    ' Set the score to -1 so it won't show up again
    scores(highestIdx) = -1
    ' Update the text fields on the page
    if self.GetObjectByName("Name " + CStr(j) , txtobj) then
    txtobj.text = names(highestIdx)
    end if
    if self.GetObjectByName("score " + CStr(j) , txtobj) then
    txtobj.text = scorestxt(highestIdx)
    end if
    if self.GetObjectByName("Party " + CStr(j) , txtobj) then
    txtobj.text = party(highestIdx)
    end if
    next
  • 5.  RE: Auto Sort Election Results & Ideas/ Suggestions
    Posted 10-16-2015 01:14
    Thanks! :)
    I may need some help implementing this, I'm pretty new to the scripting side of Xpression.
