I'm having an issue where the text I type out in the layout mode is not showing up the same in the sequence mode. For example, In layout I have text that is red with black stroke and hard drop shadow and in the layout mode the text appears white with soft drop shadow.
I'm also having the issue where text I type in the template data (sequence mode) does not match what is output. I type a number "24" and the output is "34".
What the heck is going on? Thanks
