  • 1.  Font color depends of text value
    Posted 10-24-2016 11:26
    Hello. Stuck here with automate font color from its text value. For example: green if lower than 4 and red if higher or equal . Can I do it without input selector node? (got Xpression designer 5.7)
  • 2.  RE: Font color depends of text value
    Posted 10-24-2016 11:48
    Input Selector is "Selector" in 5.7
  • 3.  RE: Font color depends of text value
    Posted 10-24-2016 11:55
    But how can I use it in this case?
  • 4.  RE: Font color depends of text value
    Posted 10-24-2016 12:03
    Like this post... You always had a condition block which return 1 and the others 0, so with selector and font tags, you can do what you want...
  • 5.  RE: Font color depends of text value
    Posted 10-24-2016 13:17
    Thank you. Done with Vlogic to switch between 5 colors that is depends of text value. In my example this is Rush Hour road situation infographics (color sets from green to dark red). Attach example to help other who interested:
  • 6.  RE: Font color depends of text value
    Posted 10-24-2016 13:29
    Ahhh, ok... You want to change a color, but not a font color... ahah ! Well done !
