  • 1.  Xpression setup for elections with Newsroom Solutions
    Posted 01-22-2014 00:13
    Is there documentation on how to set this up? We have templates made for Xpression, but I would like to get a jump on March elections and thought that someone mentioned there was some instructions for this.
  • 2.  RE: Xpression setup for elections with Newsroom Solutions
    Posted 01-22-2014 01:01
    There is no documentation specific to the Newsroom Solution Newsticker system specific to XPression.
    However, technical support has set up this system several times in the past with success. I would recommend reaching out to them to get in contact with an XPression specialist.
    techsupport@rossvideo.com
  • 3.  RE: Xpression setup for elections with Newsroom Solutions
    Posted 01-22-2014 01:12
    Thanks Garner!
  • 4.  RE: Xpression setup for elections with Newsroom Solutions
    Posted 01-22-2014 16:11
    At WREX, we use Newsroom Solutions and XPression, and have successfully for about 4 years, now.
    We contacted NS and had them set up an .xml of our election data, which they created on our local server. We then used that .xml as a DataLinq source by using the RSS DataLinq type. Each race then has its own set of scenes for display. Some for full-screen with headshots, some as an on-camera overlay.
    I know other stations have been able to use a variation of t-prompt and CII to push this info from NS to XPression, but I have not personally gone that route.
