  • 1.  Small scripting question
    Posted 02-14-2013 16:53
    I'm pulling headlines from an RSS feed for crawl. Almost all of the headlines have an image tag at the beginning of them, so I've set up a hidden text object to split the text and send just the headline info to a text object that's visible. The script is on the hidden text object and looks like this
    dim line as string
    dim segments(2) as string
    dim textobj as xpTextObject
    line = Replace(text, ">", ";")
    segments = Split(line, ";", 2)
    if Scene.GetObjectByName("Headline", textobj) then
    textobj.text = segments(1)
    end if
    How can I make this script conditional? If the headline has an image tag then it splits and if it doesn't have an image tag then it doesn't?
  • 2.  RE: Small scripting question
    Posted 02-14-2013 17:42
    Hi WDAY,
    You could check first if there is an image tag and only then execute your code. Otherwise it will take the entire string as a headline:
    dim line as string
    If InStr(1, text, "") > 0 Then
    line = segments(1)
    else
    line = text
    end if
    textobj.text = line
    end if
    Ofcourse you need to replace the "" with your imagetag which is in the string.
    Is this what you were looking for?
    Best regards,
    Kenneth
  • 3.  RE: Small scripting question
    Posted 02-14-2013 17:55
    That was exactly what I was trying to do! Works like a charm. Thanks so much.
  • 4.  RE: Small scripting question
    Posted 02-14-2013 19:24
    You're most welcome!
    Is there a reason actually why you replace the > with ; ?
    Because otherwise you could split it directly on the > ?
    Best regards,
    Kenneth
  • 5.  RE: Small scripting question
    Posted 02-14-2013 22:38
    No, there wasn't a particular reason. I was just using a bit of script from another scene and just kept the format the same since I knew it worked. Thanks for the tip!
