Hi all,
I'm attempting to use the Xpression Video Coder to prepare existing video clips for import onto Xpression.
Coming from a MAC platform, I'm rendering out of After Effects as quicktime with H264 compression, then converting to an .AVI using 'MPEG Steamlip'.
Is there a specific file format/compression codec combination that I need to use so I can import into the Video Encoder?
