  • 1.  'Glass' Material
    Posted 03-30-2015 19:16
    Has anyone had success simulating glass on a 3d object either on an Xpression primitive or on an imported 3d object? I want headshots to look as if they are backed by a glass plate with beveled edges.
  • 2.  RE: 'Glass' Material
    Posted 03-30-2015 19:34
    Hey Malcolm,
    I already had some succes using the texture below, which I copied from a demo-project of Ross :-)
    Try if this works?
    Cheers,
    Kenneth
  • 3.  RE: 'Glass' Material
    Posted 03-30-2015 19:35
    The image doesn't seem to work but try this link:
    https://www.dropbox.com/s/kklez3kdyn51noj/reflect%201.jpg?dl=0
  • 4.  RE: 'Glass' Material
    Posted 03-30-2015 19:42
    apply this as a reflection map or as a material. The look I am after is a transparent quad with little depth, beveled edges and specular highlights along any edge.
  • 5.  RE: 'Glass' Material
    Posted 03-30-2015 19:51
    As a material. You might have to play a bit with the alpha.
  • 6.  RE: 'Glass' Material
    Posted 04-01-2015 14:22
    I just made a glass plate in photoshop and dropped it in as a material with shader for use here. I haven't tried making a material from scratch in XPression, but I'll take a look at what Kenneth posted.
  • 7.  RE: 'Glass' Material
    Posted 04-01-2015 16:48
    Dan, given that glass is transparent, what does your material look like? perhaps something about 10% opacity?
  • 8.  RE: 'Glass' Material
    Posted 04-01-2015 16:53
    http://imageshack.com/a/img537/3538/joGQUv.png
    That's the image I use. I vary the opacity and specular lighting depending on the scenes' needs. I use that all over the place; for sports, elections, anytime I need something thrown in. If you were to combine a reflection map with it, it would probably work pretty even better.
  • 9.  RE: 'Glass' Material
    Posted 04-01-2015 17:26
    ok, I will start playing. Thanks Dan
