  • 1.  Ability to copy datalinq data into the static text tab in sequencer?
    Posted 10-23-2014 23:43
    Hello All... I'm hoping to find a way to take a scene that is datalinq and copy the datalinq data from the field and paste it into the "Static Text" tab in the sequecer for that specific scene. Because of workflow issues it will help me immensely if, from the sequencer, if I have to edit datalinq text I could simply press the "Static" tab and have the datalinq data already in the "Static" tab.
    I tried this with VisualBasic. Connecting a [Datalinq Data] directly to my [Text] "Text" field. Maybe there is a step I'm missing. Or is it even possible to accomplish this?
  • 2.  RE: Ability to copy datalinq data into the static text tab in sequencer?
    Posted 10-24-2014 07:34
    This might help....I've "copied" text and images from one quad to another using Visual Logic to build both left and right versions of an OTS in the same scene. Not at my machine, but try linking the text.face of the DataLinq'd text to text.face of a duplicate static text object. Publish the visibility of both versions and choose the one you want in the sequencer. You might encounter a problem if the DataLinq'd object updates.
  • 3.  RE: Ability to copy datalinq data into the static text tab in sequencer?
    Posted 10-24-2014 13:49
    Rightclick on the take item and use this option:
    [IMG]http://i.imgur.com/fbYJ7fp.png
    [/IMG]
  • 4.  RE: Ability to copy datalinq data into the static text tab in sequencer?
    Posted 10-24-2014 15:03
    Brian! That is awesome. I wasn't even aware that feature was already available. Thank You. Looks like I need to go through all the menus options again for a refresher. Thanks Again.
  • 5.  RE: Ability to copy datalinq data into the static text tab in sequencer?
    Posted 10-24-2014 15:06
    I hope it is in your version :) You should probably make sure you are on version 5.7
  • 6.  RE: Ability to copy datalinq data into the static text tab in sequencer?
    Posted 10-24-2014 19:16
    I'm using 5.5 but the option is there.
