  • 1.  3d geometry import and editing
    Posted 06-29-2015 17:50
    I am importing geometry from 3ds max in .3ds format. When I make edits in 3ds max and export only the objects I have edited they are no longer in register with the objects in the xpression project. Is there a workflow so that I dont have to re-import the entire group of objects and rebuild the whole xpression project every time an element needs to be edited in 3ds max.
    ME
  • 2.  RE: 3d geometry import and editing
    Posted 07-09-2015 16:51
    Hey Guys no comments on this?
  • 3.  RE: 3d geometry import and editing
    Posted 08-11-2015 13:55
    So are you talking about an import and replace existing function ?
  • 4.  RE: 3d geometry import and editing
    Posted 08-11-2015 17:44
    Just trying to develop a workflow that allows me to go back upstream and make changes to my 3d geo in AutoDesk 3dsmax and then re-import that geometry into Xpression. As is is now when I do that the results are unpredictable.
  • 5.  RE: 3d geometry import and editing
    Posted 08-11-2015 17:48
    I'm assuming even though you're probably using the same name for the file,etc Xpression stills sees it as "new" geometry. I have the same issue in C4D, I tweak a model or whatever and have to re-import, reposition, etc. Pain in the arse.
