  • 1.  Blank Keys
    Posted 11-25-2014 21:10
    We are having an odd issue with our Xpression system. We are using the remote sequencer in conjunction with iNews (plug in) that talks to the Xpression Studio to generate the keys. Whenever a producer updates or adds a key in the story line that we are using on-air the key that is on air will lose all text (it will keep the banner). In the past it would only happen if the key that was on-air was updated - now it affects all keys in that story slug (in iNews). Is anyone else having this issue or has run into this issue before?
  • 2.  RE: Blank Keys
    Posted 11-26-2014 19:00
    Hi Michael,
    I am working directly with Lesley to resolve this issue. To my knowledge, I believe this issue is unique to your station.
  • 3.  RE: Blank Keys
    Posted 11-28-2014 20:02
    We had issues with things disappearing, and it turned out that we needed to have the graphic at a lower Z value than the text, essentially they were fighting to be on the same place in the Z plane and it was random which item would win out.
  • 4.  RE: Blank Keys
    Posted 11-30-2014 14:29
    Thanks for the info Lorraine, I will forward it on to our graphics guy.
