  • 1.  Ortho Camera and Effects
    Posted 03-16-2015 19:47
    When I use an ortho camera it causes objects to disappear that have effects on them. If I deselect the effect or switch to the default camera the objects become visible again.
    Is there a way around this or am I missing something?
    Thanks all.
  • 2.  RE: Ortho Camera and Effects
    Posted 03-19-2015 14:25
    Can you post a project that demonstrates the issue you are describing?
    Also what version and build of XPression are you running?
  • 3.  RE: Ortho Camera and Effects
    Posted 03-19-2015 15:03
    Garner,
    Here is a wetransfer link for a package containing the scene. http://we.tl/ftOppiXxvj
    I have two cubes called "1st Yellow Flash" and "1st Yellow Flash2", each have a bloom effect on them. If you run AnimController1 with orthcamera active and not you'll see the issue.
    I'm on Studio 5.9, build 3145.
    Thanks for your help.
    Taylor
