  • 1.  XPression MOS editor question EDIT: issue resolved
    Posted 10-01-2015 19:38
    EDIT: Nevermind, I have resolved this issue! Sorry for the confusion.
    Hey everyone. I posted a question here a week or two ago and got a prompt answer that really helped me out, so thanks for that. I thought I'd try again asking another basic question as I'm still new at this job and figuring out even basic, fundamental tasks.
    I previously asked how to get a CG template into the MOS editor in iNews so it would be editable by newsroom personnel. I was able to get that done after creating the graphic, but I'm confused as to how I can order the actual editable content items in the "object/field" section of the MOS editor. Basically, the way that the objects are listed in the Object Manager in XPression is in order, but in the MOS editor, they're listed out of order, something that should be near the top is at the very bottom of the object/field list in the MOS editor, if this makes sense. In the Object Manager in XPression, they're in order. What do I have to do in XPression in the object manager to re-order the object list in the MOS editor?
  • 2.  RE: XPression MOS editor question EDIT: issue resolved
    Posted 10-01-2015 20:13
    Select a text object in the scene, then look for the Tab in the Object Inspector labelled "Template Links". On that tab you will find a "Published Object Order" bxo where you can adjust the order of published fields to be the order you want. Save and republish the project to Inews..
