  • 1.  Datalinq for End Credits Roll
    Posted 10-02-2014 17:55
    I have my end credits in a .txt file but when I run them it only plays Row 1 and Column 1 or any single cell. How do I specify for it to play all 160 lines in the column?
  • 2.  RE: Datalinq for End Credits Roll
    Posted 10-02-2014 18:05
    This guide explains how to use the increment to step through the lines of an RSS feed. The concept is the same for any data source. You'll specifically be interested in steps 8-12.
    How To Step Through An RSS Feed
    (Link expires in 7 days)
  • 3.  RE: Datalinq for End Credits Roll
    Posted 10-02-2014 18:09
    I will give it a look. Thanks
  • 4.  RE: Datalinq for End Credits Roll
    Posted 02-06-2015 15:35
    Im trying to do the same thing but with a Access DB instead of RSS. Any chance you could repost the guide as the link has expired?
  • 5.  RE: Datalinq for End Credits Roll
    Posted 02-06-2015 15:40
  • 6.  RE: Datalinq for End Credits Roll
    Posted 02-07-2015 19:51
    Hi Garner,
    It would be great if this document, as well as other documents/example projects you guys supply us, would be available as download in the download section of the community instead of you posting it as an expiring link. This will make sure that every community member can download it. Now, but also in the future.
    Kind regards,
    Gerard de Vries
