  • 1.  camera switch test file
    Posted 04-01-2014 07:39
    in the attached test scene:
    https://www.dropbox.com/sh/6m2o5gotyf849ro/A3V-fOaY6A
    I am trying to find out why my cam1/scenedirector1 animation doesn't loop when triggered directly but does when triggered from a data page
    cam2/scenedirector2 animation loops using either method to trigger
    thanks!
  • 2.  RE: camera switch test file
    Posted 04-02-2014 20:27
    Hi Ronen,
    It does seem to be looping ok for me when triggering the Scene1 take item directly...
    The animation seems a bit jerkey at the very end before the loop but that just seems to be because the event is not quite at the end of the anim controller..
  • 3.  RE: camera switch test file
    Posted 04-02-2014 20:31
    Hi Brian, thanks for looking at this - the animation is jerky because this was a quick little test
    for some reason when I directly set the value to 1 in the scene item (not the data page) the animation isn't looping - it plays one time then stops
  • 4.  RE: camera switch test file
    Posted 04-02-2014 20:34
    hmm.. I totally understand what you're describing, but it definitely loops here.. I'm using a slightly newer version than what you show in your screenshot.. Let me roll back to your version and try again..
