  • 1.  Sending commands to the CII gateway
    Posted 11-04-2014 16:28
    i want to build a little application which sends CII commands to our Xpression BLuebox with the CII gateway installed.
    Is there any documentation available for this?
    i can't find any documents on the www.
    Many thanks in advance
    Jan Augenbroe
  • 2.  RE: Sending commands to the CII gateway
    Posted 11-04-2014 16:30
    The protocol for the CII gateway is actually available in the Start Menu under the CII Gateway folder.
    It is a PDF with all of the commands which you can send to the CII gateway.
  • 3.  RE: Sending commands to the CII gateway
    Posted 11-07-2014 09:26
    Hi Brian,
    I have found the document.
    and i am able to connect to the CII gateway :)
    but i think the command i send are not recognized yet.
    tha PDF document says:
    Each command string must be terminated by two backslashes, followed by a carriagereturn
    linefeed sequence (0x0D 0x0A).
    maybe can you provide me a example string to send to the CII gateway?
    regards
    Jan
  • 4.  RE: Sending commands to the CII gateway
    Posted 11-17-2014 19:44
    I am trying to update a Quad material by using CII command,
    U\\12\\1\\Z:\\\\temp.png\\\\
    E\\Incorrect checksum received.\\\\
    but, i got this error message back
    Did I make any mistakes in there?
    Thank you
  • 5.  RE: Sending commands to the CII gateway
    Posted 11-19-2014 00:14
    Try to change the backslash in your image path to a forward slash, e.g. Z:temp.png to Z:/temp.png.
    You can't send a backslash in the CII protocol because it is used as the delimiter between fields in the message.
