We used stagger animations to bring in our the text on our full pages. I noticed that if Squeeze is enabled, longer text will peak out from the left side of screen before it's been animated in. It appears that the offset value is shrunk along side the bounding box of a text object. We have currently set the x offset value to -2000 for some buffer room but I believe I should only have to set it to -1280 tops to make sure the text doesn't appear before the CG op triggers it.
Has this been a problem for anyone else?
