  • 1.  Live Source in Prime
    Posted 01-22-2014 16:39
    Hello, we want to add a Live Source - either via Directshow ( which should work with Prime) or directly. We can add the card to the Xpression System without a Problem.
    We cant add it as a Texture Layer - Live Source - Apply Live Video Source to surfaces. Its just not there.
    Any idea why ?
    Thank you for help
  • 2.  RE: Live Source in Prime
    Posted 01-22-2014 18:45
    Hello Dirk,
    It's normal, the livesource shader is not included in the Prime versions.
    You can see the installed options on this sheet http://www.rossvideo.com/images/xpression/comparison_table.jpg
    Best regards,
    Kenneth
  • 3.  RE: Live Source in Prime
    Posted 02-07-2014 13:13
    Yes i know. But the Table also says it supports Directshow ( Webcams)
    Doesnt it mean it should work with this then ?
