  • 1.  Material Thumbnails not displaying
    Posted 08-27-2015 19:55
    I just upgraded to a new machine that I will use Xpression Designer, and I am not able to see the thumbnails for the materials. It will only show a black square.
    My previous machine did not show thumbnails either, that would either show some garbled mess or just black. I have set the Hardware Renderer to the graphics card, but that does not help. Is there a setting somewhere I am missing?
    Thanks for your help.
    Mike
  • 2.  RE: Material Thumbnails not displaying
    Posted 08-27-2015 20:01
    Is this on a Windows Machine? A Virtual Machine? An Apple machine on Bootcamp?
  • 3.  RE: Material Thumbnails not displaying
    Posted 08-27-2015 20:12
    Good point. Some detail: This is Windows. Its a Dell M3800, i7. It is Windows 8, not sure if that matters, I have read others are using it.
    It has an NVIDIA Quadro K1100 Graphics card. In Xpression under Preferences, I go to Hardware Renderer, I don't see that adapter as a choice, only Intel HD Graphics 4600. Could that be a factor?
    Thanks for your help .
  • 4.  RE: Material Thumbnails not displaying
    Posted 08-27-2015 20:21
    Very strange, I understand the software requires Windows 7, but we have had it operational, however poorly operation on a Windows 8 machine that we no longer use. That seems like a very solid machine being the professional level laptop Dell offers. Have you navigated to Edit > Hardware Setup? There I believe you have more control over where your outputs go. Are you trying to virtually output or output to a technical board?
  • 5.  RE: Material Thumbnails not displaying
    Posted 08-27-2015 20:31
    Hi Mike,
    The material thumbnails will not work unless the NVIDIA board is the active renderer. You will need to look for a setting in the control panel (maybe in the nvidia control panel if there is one) to force it to always use the NVIDIA board. I have seen this issue on other laptops before where the default to using the onboard lower power Intel GPU unless you force them to use the faster NVIDIA gpu.
  • 6.  RE: Material Thumbnails not displaying
    Posted 08-28-2015 12:19
    Yeah, this was a setting to do with the computer not using the NVidia as the default graphics renderer for the program. To fix, I right clicked on the desktop. Go to the NVidia control panel and make the default processor for Xpression.
    Easy fix!
