Hi all,
So, obviously you can't animate the texture position of text within XPression. Although I believe there is some Visual Logic magic I can employ here to animate text in and outside of it's bounding box as if to mimic a precomp within After Effects. The problem is I have no idea how to employ said Visual Logic.
@bford would you have any input on this?
