  • 1.  Line spacing in credit rolls using the Group Scene function
    Posted 01-28-2016 18:32
    Hi, I'm having a problem with line spacing in between multiple scenes when doing a credit roll. We can crop the scenes top and bottom globally but I don't have the same number of lines with text in every scenes making it difficult to get an even spacing in between scenes. Any idea? Sometimes I import a TEXT file in a scene that I made in Word and do the roll using a group Roll in the sequencer. If I have to much text and graphics it slows down the CG too much. There has to be a simple solution I'm overlooking right? Thanks for your help.
  • 2.  RE: Line spacing in credit rolls using the Group Scene function
    Posted 01-28-2016 22:15
    It's difficult to understand what you mean when you say you "crop the scenes top and bottom globally"... Are you referring to the Global Margins setting? This should not crop, but rather inserts blank space between each child scene. Each child scene in the crawl also has a "margins" setting on the Roll/Crawl tab that can affect the spacing individually on that scene..
    If you post a link to your crawl scene it might help people to see what you are having an issue with.
