Hi There,
I'm using Xpression Studio (Build 2116) and setting up a scene with some Phoshop files including a (drop) Shadow. And the transparant parts (the shadow) are messing up....
When importing the PSD files into the Xpression Bin, and looking at the RGB images/Alpha-Channel something wierd is going on. The Alpha channel is ok, but within the RGB Image everything what used to be transparant, is white. So when using the image (and specific my drop shadow) isn't black, but white...
Why does Xpression think that my PSD background color (which is transprant) is White?
Within Xpression AVIS I can set this up right by using the shaped/unshaped option. What can I to with PSD files to get the good result?
